AutoLISP 101 - Entity Names - Discussion
Entity Names
Entities are necessary for manipulating data in drawing files.
All graphic items (lines, circles, etc...) are entities.
Useful Entity Functions
(entlast)
will return the last graphic entity in a drawing.
(handent "1C7")
will return the entity associated with the unique hexadecimal identifier called a handle.
(entsel)
will prompt the user to select an object and return a list with two items including the entityname the point selected.
So...
(car (entsel))
will return a selected objects entity name (car returns the first item in a list)
So to get and store an entityname you use the setq expression.
(setq entSelection (car (entsel "\nSelect One Item: ")))
the entsel expression allows for a prompt ("\n" is a carriage return)
The default prompt is "Select objects:"
There is also
(setq entSelectionNested (car (nentsel "\nSelect nested item: ")))
Which allows the user to select items nested inside other items (like blocks)
Try it and comment to the discussion thread.
Re: AutoLISP 101 - Entity Names - Discussion
You can use also (ssname)!
((lambda ( / js n)
(setq js (ssget))
(cond
(js
(repeat (setq n (sslength js))
(print (ssname js (setq n (1- n))))
(prin1)
You are absolutely right.
I have not got to selection sets yet...
It is on the list.
I just wanted to make each of these posts relatively short.
Entity Lists, Tables and Selection are up soon.
P=
