RE: Levels have disappeared
Originally Posted by Chad Smith
I have a project that I have started in r7.0, and it has come time to work on the elevations and sections.
But when I open any of these views, I have no level lines, not one.
The scope of my elevation and section markers in plan encompass the entire building, and the level visibilities are on.
Does anyone have any suggestions, or should this be forwarded onto Autodesk?
Hi Chad,
Have you checked that the scope box of the view is not to high?....i.e. I see that you've checked the scope boxes in the plan, but have you checked the scope box in the Elevation view?
John Mc
1 Attachment(s)
Everything seems to be in order, and I can see all the objects that I have placed in the project in the elevation and section views.
I think it's time to send off to Autodesk.
.......I think it's time to send off to Autodesk.
...hmmm....sounds like it....The views seem OK, don't they.
I wonder if it has something to do with these despised 3d levels?
Turn on crop regions, pull crop regions way out into space....find level lines, drag back into the view area, reset crop regions.
I was just about to ask the same question..
Many levels seems to just disappeared to thin air.........
I thought I had the 2D/3D concept down to a fine skill, and was wondering why everyone was having difficulty with them and why they hated them (I certainly didn't).
If it is related to the 2D/3D, then my opinion will change.
One of the first things I tried, but I just can't find them.
NOW I remember!....Yes!!!!....What Scott said!.....I knew I had a similar problem ....trouble for me is I have so much "trial and error" fixing of problems, I can't remember what I did where!
perchance - did you copy the elevation tag in plan view? I did this and 3d levels disappeared altogether for no reason. I also saw the scale had reset to 1:1 meaning no levels were shown. Indiscriminate. I had to re-copy the tag and reset the scale, zoom out and reset the default crop regions prior to applying the view template.
