I need to add up the total length of all of the contours in an area. The contours are LDD contour objects. Does anyone know of a routine that will add the lengths of selected contours or polylines?
Printable View
Hi
Below routine is from an old LISP Guild post by Stig Madsen -
Code:(defun C:PLINELEN (/ ent sset obj len sum layer a)
(setvar "ERRNO" 0)
(while
(and (not (setq ent (car (entsel "Select object on layer: "))))
(/= (getvar "ERRNO") 52)
(cond ((and ent
(setq sset
(ssget
"X"
(list '(0 . "LWPOLYLINE")
(cons 8 (setq layer (cdr (assoc 8 (entget ent)))))
(setq a 0
sum 0
(repeat (sslength sset)
(setq obj (vlax-ename->vla-object (ssname sset a))
len (vlax-curve-getDistAtParam
obj
(- (vlax-curve-getEndParam obj)
(vlax-curve-getStartParam obj)
sum (+ sum len)
(setq a (1+ a))
(princ (strcat "\nTotal length of "
(itoa a)
(if (= a 1)
" pline on layer "
" plines on layer "
layer
(rtos sum)
(T (princ "\nNo plines found"))
(princ)
OR
Check out something like the following -
[size=2]]CADalyst Get the Code August 1999 - Pline Lengths
Have a good one, Mike
You say LDD contour obects, if I take this to suggest
that you have Land, and MAP at your disposal
just use a MAP query of those objects, and set it to
write a report of all the objects lengths in a comma delimited file
and add them in Excel.
I copied the text to a text file, saved with a .lsp extension and used APPLOAD to load the application, however, I keep getting "Unknown command" ? when I type the new command name on the command line?.
Using AutoCAD 2004
Any ideas?
Hi
Worked for me (just tested a few moments ago).
* Copy & Paste Code into an ASCII text file (eg NotePad)
* SaveAs PlineLen.lsp
* Load into AutoCAD
* At AutoCAD Command Line type PlineLen
Just out of curiosity, why do you want to do that?Quote:
Originally Posted by jbenway
It's grt...... I was about to create a lisp on my own... but i got a flash to check any post available related to my need....and I found this exactly meets my requirement... It saved me lot of time and effort..... Thanks for the creator......
