Creating surface profile over Pipe location that is shown in centerline profile
I would like to have the surface profile I am showing in my profile grid reflect the actual surface over the path of my pipe design.
the only way I can figure to do this is to create an alignment for both the C/L of the road and another alignment for the pipe path.
Then I also need to create 2 separate surface profiles,
and then superimpose the pipe surface profile onto the centerline profile.
This basicall double my work load.
Does anyone have a better solution??
Thanks
Re: Creating surface profile over Pipe location that is shown in centerline profile
Hello Karen,
I am having the same issue. Did you ever find a solution or workaround?
I think are correct. You have to create the second alignment and profile then superimpose it onto your first. Probably make the style for your pipe alignment as a no display.
karen.cohen593070
Thanks
