Unknown command message appears on command line, after executing a routine
I have written some routines that work just fine, but for some reason I always get "unknown command" on my command line after i have executed the routine. Is there a way to get rid of this? I have placed (princ) at the end of my routines.
Any help would be great
Emily
RE: Unknown command message
Could you post the code so we can have a look and see where it is failing? It would be a lot easier that way.
RE: Unknown command message appears on command line, after executing a routine
Emily
If you run it in the debug mode, you can single-step through lines of code until you hit the one that blows up. You can also try turning on command echo and running your routine.
I will try and run the debug first and if it still continues or i can't figure it out i will post my code.
