What's the best way to make a Door/Window Assembly
I'm a new Revit user coming from ADT. In ADT it was really easy to make a Door/Window Assembly but w/ Revit if I use a Curtain Wall, then I can't tag the window as a window, I only get a Wall Tag. We use the same Door/Window Assemblies in every project. How is everyone doing this so that they can be tagged appropriately.
RE: What's the best way to make a Door/Window Assembly
The other problem w/ Curtain Walls is that you can't copy it and use it over again. There has to be a easier way.
Mr. Spot,
Hey, thanks for the response. I understand what you are saying about the Curtain Wall Door/Window Families, but I need to play around w/ it some more.
Clear something up for me, if I understand this correctly, everytime we want to create a Door/Window Assembly I need to create a Curtain Wall, make grids inside of it and then change the panels out to Doors & Windows. Is it possible to make a Curtain Wall that is reusable w/o having to redo the work everytime?
I feel like I'm missing something as everything in this program tends to be somewhat straight forward, but this is "blowing my mind up"! Do you have an example that might clear up my confusion w/ a multi-category tag, I can't find one of those anywhere?
-C
Originally Posted by greg.mcdowell
I think what you'll be wanting to do is make the door/window assembly a family, or series of families as the case may be, with nested and, I think, shared window and door components. It's the closest you're going to get to ADT's methodology and really not that different if you take the time to properly parametrize (That is a word isn't it?) your family including some arrays to add/remove mullions as necessary.
Yes that sounds like what I want, but how do I make a door/window assembly a family. Do I use a Door Template or a Window Template? Do have an example?
Wow this stuff is way more complicated than they show you in the demos and training classes. I've been reading about nested families and that makes a lot of sense. I'll give it a shot, thanks for the help.
Originally Posted by clintr
Mr. Spot,
-C
Maybe I missed part of it, but there are door and window families that you just place in a wall, no need to create curtain walls, grids, etc etc.
Also a curtain wall/storefront can easily be copied. I do it all the time.
Yes you are right there are door and window families, but I want a combo one that I can customize the layout of the window grid/pattern to be a office standard and not have someone have to create a Curtain Wall grid everytime and screw it up.
The curtain wall storefront may be able to be copied around once you make it but we are looking for a certain look/style, so you have to first create one and that's where the problem lies, I need it to be more automatic than that. Nested Families appears to be the way to go to achieve this. It seems to be just like ADT's Door/Window Assembly feature.
Thanks
-C
