Hello,
I would like to see the ability of when checking in a file if you could have the option to create either a DWF or PDF or both at the same time. Even though DWF is the CAD standard, PDF should be an option as well.
Regards,
Imran
Printable View
Hello,
Regards,
Imran
You've got my vote! You just can't force clients to use dwf. And even though dwf is probably better than pdf in many ways, I need to give the my clients what they want.
I would like to thank you for sharing your thoughts and time into the stuff you post!!
This feature can be used to create a link between M-Files and a scanner . Every file version created a copy of the file in the Vault regardless of if the file changed .
