Re: Having graphic and interface issues with NW2011
rsloyer
Got them to send me an NWC, and the NWC is causing the exact same problem!
Ugh. Send the NWC to Autodesk's tech support and get their take on the issue.
Got the sub to clean up the dwg, and then the nwc, and it finally worked.
Now I'm on to a new set of issues and both Navisworks and Revit both are crashing out.
So I'm being told I can't run Autodesk products with two video cards? I'm not sure why it was working fine prior to all of the 2011 versions, but now I'm crashing out on both Revit and Navisworks, and I'm only running Revit on one screen.
Whole computer crashed out requiring a complete system wipe and reinstall. Even removed the second video card. Now Navisworks is lagging horribly, takes forever to load a .nwf, and then locks up with a blank white screen and the view cube vanishes.
Good times!
rsloyer
You may want to define "can't run with two cards". I'm pretty sure Navisworks doesn't take advantage of SLI/Crossfire. Maybe somebody was summarizing a posting from the AutoCAD 2011 forum about Windows XP not having hardware accelleration on a second monitor?
Hi. Can anyone help me with making a navis model form my PDS project?
I would be appreciat it if you would help me.
