1 Attachment(s)
AutoCAD 2007 - Remove "Hide Layout and Model tabs" from right click menu
Hi this may sound a stupid question but in AutoCAD 2007 when you right click on the Layout or Model tabs its comes up with a short cut menu and at the bottom of it a new function has been added which I dont like called Hide Layout and Model tabs.
Is the way to get ride of this from the short cut menu as I keep pressing it because I am use to the Plot command being at the bottom.
I have attached a screen print showing what I mean.
Cheers
Gareth
RE: AutoCAD 2007 - Remove "Hide Layout and Model tabs" from right click menu
Hi Gareth
Please note I have *moved* this thread from the AutoCAD 2007 General forum to this one, as I believe it will be better served here.
Thanks, Mike
Forum Manager
Hi
Unless Autodesk have made the Model / Layout tab right-click menu available through the CUI or an API, I am afraid you might be out of luck.
Examples...
Right click customization of Layout shortcut?
How to disable 3DORBIT?
Have a good one, Mike
