Is there a way to have a "dummy" section tag??
I've searched all the REVIT forums and couldn't find anything about this. I'm in REVIT Structure, but this is a general REVIT question so I'm asking here.
When cutting a wall section in a model, it gives you a view, where you name it, detail it and place it on a sheet, and now it has a "home", that's perfect!
But....I want to put a section marker on other walls that have the same geometry and refer to that same section (so I wouldn't have multiple sections with the exact same information).
This is more of a company standard thing we would do in AutoCAD, it tells the viewer of the drawing(s) that that wall is built like the other wall etc. So you hard-core REVIT users, please take it easy on me, it's a reasonable request :p.
I would like to place a section marker on the plan(s) and have them refer to the same section, is this possible?
Does anyone have another idea?
The only other thing I can think of is to either bring one in from AutoCAD as a graphic entity, or figure out a way to make a dumb editable one in REVIT.
Thanks in advance.
1 Attachment(s)
Re: Is there a way to have a "dummy" section tag??
Ted,
You can. There is a check box when you are in the section command to "Reference other view". You then can select from a list of views (sections or drafting views). See the attached image.
vgonzales
Ted,
That is FREAKIN' AWESOME!
Thanks so much, didn't know that could be done.
:beer::beer:
Works with other callouts too, not just sections. ;)
tedg
Hey Ted,
Many of us here are very accepting ;)
