Is there a way to set AutoCAD 2008 so when you double click the text, it highlights and you can edit it, like 2006.
So far I can only edit text thru the properties dialog box.
Thanks in advance.
Printable View
Thanks in advance.
jmctamney,
Where do I find this variable at? cui file?
Well......one way is to type it. The other would be to use the system variable editor in the express tools.
jmctamney,
I typed it and found that it was already set to on. I guesss I will have to open 2006 and look at its settings and then compare the two.
Thanks for the info.
