I am working with Auto CAD 2006, my prpblem is can I make my own line type ?
Printable View
Hi
Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
Below snippet is from the small print on the Forum General page (also refer to attached image) -
<snip>
New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
</snip>
Hi
For starters try the information found in the following thread...
Custom Linetype
Have a good one, Mike
Sure. Have you ever made one before?Quote:
Originally Posted by mujeebpc
You might start by studying the syntax found in the customization guide [F1 key], then use the -LINETYPE command. This creates the linetype definition using the command line without leaving AutoCAD. Good if you know the syntax and only have to do one.
If you have more than one to define, create a .LIN file using Notepad, or some other ASCII text editor.
You could also use the MKLTYPE command (part of Express Tools)
Complex linetypes can be a little tricky, especially if you are using shapes. Express Tools also includes a MKSHAPE command to help with this part. If you use text in a complex linetype, create a textstyle dedicated for this use, and set it's fixed text height to 0.
Lastly, if you have a drawing that contains a linetype that you want to add to your collection, then pick up NEW-LIN.LSP and/or TO-LIN.LSP from http://www.turvill.com/t2/free_stuff/index.htm. These routines will create a LIN file from linetypes in any drawing.
How do you make the *.lsp file run (work)??
Have you tried the appload command?Quote:
Originally Posted by dkaiser.103387
You may also want to look at this thread (Running Lisp).Quote:
Originally Posted by AutoCAD Help
