Is it possible to control the visibility state of one dynamic block with the properties (visibility state) of a second different and separate dynamic block.
Thanks for the help.
Rob Marsillo
Printable View
Rob Marsillo
No.
What Block have you ever created that changed a parameter of another Block?
If you name the visibility parameter and the visibility states exactly the same between the 2 blocks when they are both selected at the same time the property will be available to modification.
I dunno if this helps you.
