Custom Hatch Pattern Help
Good afternoon,
I have been trying to get a custom hatch pattern figured out for 2 hours now, and am at my wits end.
I am trying to create an 8x16 CMU course, and then a 4x16 course (staggered joints) underneath it. I can get the horizontal line spacing no problem. My problem comes when trying to get the vertical lines to work correctly. I can easily make the joints line up but, as I stated above, I would like to have staggered joints between the 4" courses and the 8" courses. Any help would be greatly appreciated.
Here is my horizontal lines code:
*Block 8x16-4x16, 8x16 + 4x16 blocks running bond
;%TYPE=MODEL
0,0,12,12,12,12,12
0,0,4,12,12,12,12
1 Attachment(s)
Re: Custom Hatch Pattern Help
The attached has two infinite lines for the horizontal joints and evenly staggered verticals.
hth
Hugh Adamson
www.hatchkit.com.au
Is this what you are after:
*Block_8x16-4x16, 8x16 + 4x16 blocks running bond
;%TYPE=MODEL
0,0,12,12,12,12,12
0,0,4,12,12,12,12
90, 0,0, 0,16, 4,-8
90, 8,4, 0,16, 8,-4
hugh.69031
hth
Hugh Adamson
www.hatchkit.com.au
This worked perfectly...thanks so much Hugh.
msretenovic
;%TYPE=MODEL
0,0,12,12,12,12,12
0,0,4,12,12,12,12
90, 0,0, 0,16, 4,-8
90, 8,4, 0,16, 8,-4
Again,
thanks for the response...works great.
....must be close to the weekend....2 hours trying to figure it out, when it only takes 2 minutes on the forum here.
