I am having a problem with the ceiling grid command. The layer that it inserts on is green but for some reason the ceiling grid comes in as a different color. Is there someplace I can change it insert with color by layer?
Printable View
Which version or vertical are you using? Sounds like an ACA command. Maybe you'd be better served on that forum?
Using AutoCAD Architecture 2011. I'll try posting there and see if anyone knows! Thanks.
