Help with symbol file customization please
We're running AutoCAD Electrical 2010 and we have our symbol library located on a drive other than "C". We recently migrated from 2008 and I can't remember how the settings were under the "files" tab. If we want to point to a different location than "C" for our symbols do we do that under the "support file path" or the "working support file search path" ?
Any help would be greatly appreciated.
Re: Help with symbol file customization please
I would try the first as the second is the list of folders that AutoCAD can access.
Autocad Electrical is a bit different. Check your help file, there is one path for electrical that needs to be the upper path the first that gets checked, this is due to the environment file reading that.
Also look at your project settings and properties and make sure you set your symbol libraries.
Patrick Johnson
http:\\www.cadenhancement.com
