ADT 2004 - List length of Lines without using the List command
I'm trying to help out the estimating department with a layout of a tongue/groove boards used on a ceiling. The question is there anyway to list the lengths of the lines without just using the list command so that it can be put into a words doc or excel spreadsheet? For your reference I'm using ADT2004.
RE: ADT 2004 - List length of Lines without using the List command
Hi "PHOTOS4ME"
Please note I have *moved* this thread from the AutoCAD General forum to this one...
Why? - ADT may offer additional functionality that vanilla AutoCAD does not...
Thanks, Mike
Forum Manager
What are you using to model the boards? You may be able to create a Schedule Table that lists the lengths and has a total length at the bottom of the length column.
I'm a little confused by your estimating department. If you consider that ceiling boards are substantially similar to wood plank flooring, most of that should be estimated by square feet. If you use square feet for calculations, you can use the floor area for the ceiling area, if the ceiling is flat. If it is sloped you can use a slab.
For what its worth in the UK timber t+g strips/planks can be sold in linear metres, but we would still put down the square metre/feet to calculate costs.
i know that if the boards were to be straight figuring the square footage would work. But if the these were to be curved on a 90 foot arc i didn't know if it would be that easy
This the way I would go.
- add a new property set definition that applies to lines
- add a automatic property for Length
- add a new Schedule that use your new property set definition
- insert the new schedule table
- set the layer wildcard in the schedule table to the layer the lines are on
- attach property set to the lines
- You can who export the schedule table
