Re: Spaces and floor levels
Craig King
Hi,
I am having trouble with defining Levels for spaces in projects. I have a four storey building with each floor plan set as a different level but when I add the spaces to each floor the SpaceObject property set "Level" shows NA.
I would be grateful for any help/guidance
Thank you
When you say "project", are you using that term in the general way, or are you referring specifically to AutoCAD MEP "Projects" as created in the Project Browser and as organized, developed and edited via the Project Navigator? The Level property is a Project property, and as such, will only have a value when the drawing in which your Space resides is part of an AMEP Project, and included in a Construct file (either directly, or in an Element file that is then externally referenced into a Construct file.
David,
thank you for the reply. I was referring to an AMEP Project. I think my problem was due to not having the spaces referenced to a construct
