Actually, there are a series of commands that act differently in AutoCAD 2009 and higher. However, the fix is easy.
Read up on the new initcommandversion function.
Printable View
Thanks Robert.
Please also read the following:
http://usa.autodesk.com/adsk/servlet...linkID=9240617
Please take a note:
There is an incorrect statement in the article
With the latest version, the fillet command options actually look like this:Quote:
To use the newest command behavior, add the ^R control sequence before the command in the command macro. The following shows the same command macro using the new ^R control sequence:
^C^C^R_fillet;u; r;0.1;
The command prompt and options for the above command macro look like the following:
Current settings: Mode = TRIM, Radius = 0.1000
Select first object or [uNdo/Polyline/Radius/Trim/mUltiple]:
Therefore, my suggestion is that don't use shortcuts in your code, like U, P, and so on...Quote:
Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
ALWAYS use full word for the options to be executed.
This should be it:
