1 Attachment(s)
Text within Block out of alignment when associated with a MultiLeader
I've been playing with the new multileader function and have come across a problem. When using a block for annotation, the text is slightly out of alignment (see attached jpeg).
Has anyone else come across this, and is there a way to fix it. Appreciate any feedback.
ska
RE: Text within Block out of alignment when associated with a MultiLeader
Hi
Can you please post an actual drawing file that exhibits the behaviour you have described above...
Have a good one, Mike
i have noticed that the text doesnt get placed in the same location as when you use a qleader. I have been experimenting with a lisp routine that converts qleaders to mleaders and have noticed a few other slight differences between them.
1 Attachment(s)
Mike,
Thanks for your response. Here is the dwg file showing both a standard block & a user defined block. I have discovered that if I use a space before my text, the alignment is perfect.
ska
Hi
No worries...
Does this particular issue / problem occur in all your DWG files?
Only ask as I am seeing the issue / problem in your attached DWG file (multi.dwg), but I do not see the same issue / problem in DWG files I have created.
*If* I have the time, I will compare multi.dwg with a good DWG file, and see if I can identify the cause of the issue / problem.
ps In future it might be best not to post DWG files to the AUGI forums with VBA Marcos embedded in them.
Mike,
Yes, this occurs with all my and my co-workers drawings. Sorry about the macro, forgot it was there.
ska
I have this problem as well. When I use the our companies ITEM block instead of MTEXT the attribute sits to the left of centre. Is there a fix for this? This is a great function but I can't use it unless it works properly.
I will check up again to see if there is a solution.
I've found that if I add a space to the beginning of the text, it is perfectly aligned for some reason.
ska
