Merging Saved file name with Iproperties
When I save a part file, then open said part files Iproperties the file name comes up under the general tab as it should but instead of going to the Summery/Title location it shows up under the Project/Part Number location. This means I have to change the file name position manually when I update Iproperties. Is this normal??? I have looked in various books, tutorials etc. but I haven't found any way to change this so the file name comes up under Summery/title location automatically. What am I missing.
Hopefully not clear as mud. Thanks.
Re: Merging Saved file name with Iproperties
Hello,
I believe this is normal behavior, except for Content Center components, where a title can be defined to auto-populate the Title field. There are some workarounds.
- If the part is not stand-alone, and will be an assy component, the Title field can be modified en-masse with a simple copy and paste in the assy BOM.
- Use an iLogic routine to populate the field.
I'm sure there are other options.
HTH
