Vault 2016 - File check-in file names too long
Good day.
I have a problem where, when I check in files to Vault from Outlook or elsewhere, the file name ends up being too long.
- The check in process gives me no warning to say that the file name is too long.
- It doesn’t even give me the option to give the file a smaller name during check-in.
Instead, I only find out when I try to open the file later.
- But when I get to that point, I can’t even rename the file, to correct the problem – it gives me the same error.
- I end up, unable to do anything to the file, except try delete it - and it still gives an error message then.
Please tell me the best way to prevent this from happening, or at least a workaround.
If there is a setting that prevents outlook from prefixing attachments with their parent email’s subject, I would be grateful to know about this and where to find it - AutoDesk help files are not incredibly helpful. :(
Re: Vault 2016 - File check-in file names too long
Long Path Tool is the perfect utility that can solve all the long path issues. Download this software online.
You can use LONG PATH TOOL to solve this issue. It will definitely work for you.
Hello,
I had the same problem. I didn´t know what to do so I searched on the internet for some solutions.
And I read about Long Path Tool, which is a great tool in these type of cases. :o
It worked really well. Hope it works for you too :p
Long Path Tool is useful here
Long path tool is also really worked for me too. iT is very simple to learn.
