Title says it all,
For example if I have 10 pages (paper space) in one file, and I only want page 1-6, 8 & 10 to be publish into one (1) single PDF, by skipping page 7 & 9?
Any idea?
Many thanks!
Printable View
Title says it all,
Any idea?
Many thanks!
Yes, you can do this.
By how? Procedure please.
Thanks in advance.
In the PUBLISH command, use the Control key to select only the layouts to publish.
My method & the key items I double check:
Use Publish - remove the sheets from the list you do no want in the PDF file using the minus button
In the Publish dialog select Publish to: PDF
Double check the Publish Options ... [button in Publish dialog]
Make sure Multi-sheet file is checked
Optional - I check Open in viewer when done in the Publish dialog to get a quick preview in order to double check the PDF file.
(see red arrows)
