Especially given the inherent requirement of 'more lines of code' in .NET vs. LISP, etc., I wouldn't fret the extra few lines personally... Then again, I haven't coded in VB in at least a few years anyways (all of my Exchange Apps are in C#). LoL
Printable View
Moved topic of Common LISP Object System syntax to different thread.
We can continue to discuss error handling here.
Just thinking a bit, wondering if this would work. Note the idea from Gile's code (as BlackBox's link) and using the P/Invoke or the newer Application.Invoke.Haven't tested it yet, will need to do so later today.Code:using System;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
namespace ALispDotNetLink {
/// <summary>
/// Throw a generic exception to be handled by the Lisp Environment
/// </summary>
public class LispException : System.Exception {
/// <summary>
/// Constructor
/// </summary>
/// <param name="msg">The error message</param>
public LispException(string msg) : base(msg) { }
/// <summary>
/// Pass the exception to the Lisp Environment instead of stack-tracing the DotNet assembly
/// </summary>
/// <returns>Always null</returns>
public object SendLispError() {
try {
ResultBuffer rb = new ResultBuffer();
rb.Add(new TypedValue((int)LispDataType.Text, "vl-exit-with-error"));
rb.Add(new TypedValue((int)LispDataType.Text, this.Message));
LispEnvironment.Invoke(rb);
} catch (System.Exception) { }
return null;
/// <summary>
/// Throw a number-of-arguments exception to be handled by the Lisp Environment
/// </summary>
public class LispArgumentCountException : LispException {
/// <summary>
/// Constructor
/// </summary>
/// <param name="ToMany">Boolean value: true="too many"; false="too few"</param>
public LispArgumentCountException(bool ToMany) :
base(string.Format("too {0} arguments", (ToMany) ? "many" : "few")) { }
/// <summary>
/// Throw an unexpected argument type exception to be handled by the Lisp Environment
/// </summary>
public class LispArgumentException : LispException {
/// <summary>
/// Constructor
/// </summary>
/// <param name="s">Expected lisp argument type</param>
/// <param name="tv">The actual typed value passed in</param>
public LispArgumentException(string s, TypedValue tv)
:base(string.Format("invalid argument type: {0}: {1}", s,
tv.TypeCode == (int)LispDataType.Nil ? "nil" : tv.Value)) {}
Actually the vl-exit-with-error doesn't seem to have any influence on Lisp's error itself - though it does close the defun at that point. Will have to look at what can be dome otherwise.
Other than that, the only things looking promising is using P/Invoke on some of acad's loaded DLLs:
- void __cdecl error_output(char * __ptr64) in VL.CRX
- void __cdecl AcEdPromptSelection::InputCallbackArgs::setErrorMessage(class AcString const & __ptr64) __ptr64 in accore.dll
As I thought, this doesn't work. The vl-exit-with-error function only operates on separate namespaces. Will have to try and see what I can do with the other 2 p/invoke functions. The vl.crx one would necessitate VLisp to be loaded through vl-load-com, and the one from accore.dll is a bit strange - I've never used a class method through p/invoke before, but willing to give it a try.
Edit: BTW, I used Dll Export Viewer to find those other 2. There's a whole plethora of functions with error in their name, but these 2 seemed as if they might be doing what I'm after.
I have played around with pinvoke before.
Successfully created new ones.
Thanks for your work on the error handling...
I also want to continue our discussion of common lisp...
Peter
Neither of those 2 seemed to work at all. But I didn't give up - seems there's a fail function exported in VL.CRX which accepts a char-array as a string. It seems to do the job (half-way) when used in ACad Vanilla 2014:
The code to import the fail function. Note I'm exposing it in my LispEnvironment class (also contains get/set/invoke):Then the exception class, as previous, except for the SendLispError method:Code:[System.Security.SuppressUnmanagedCodeSecurity]
[DllImport("vl.crx", EntryPoint = "?fail@@YAXPEAD@Z",
CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl)]
extern static private void fail([In, MarshalAs(UnmanagedType.LPStr)] string message);
And then lastly an example use:Code:/// <summary>
/// </summary>
try { LispEnvironment.Fail(this.Message); } catch { }
return null;
It's not exactly "perfect" but it does work the way I wanted it - though there are some extra stuff printed to the command-line:Code:namespace ALispDotNetLink
/// <summary>
/// Description of TestError.
/// </summary>
public class TestError
[LispFunction ("err-vl")]
public object errVL(ResultBuffer arguments) {
try {
if (arguments == null)
throw new LispArgumentCountException(false);
TypedValue[] args = arguments.AsArray();
if (args.Length < 1)
if (args[0].TypeCode != (int)LispDataType.Text)
throw new LispArgumentException("stringp", args[0]);
return args[0];
} catch (LispException e) {
return e.SendLispError();
So for some strange reason, the *error* function does get called, but the currently running function isn't stopped. And then on the 2nd such error the entire thing fails - Access violation.Code:Command: (defun test (toEval / *error*) (defun *error* (msg) (princ "This is my error: ") (princ msg) (princ)) (princ "Result: ") (princ (eval toEval)) (princ "\n\nNo errors!!!") (princ))
TEST
Command: (test '(/ 1 0))
Result: This is my error: divide by zero
Command: (test '(/ 5 2))
Result: 2
No errors!!!
Command: netload
Command: (test '(err-vl "testing"))
Result: testing
No errors!!!
Command: (test '(err-vl 1))
Result: This is my error: invalid argument type: stringp: 1nil
No errors!!!
"\n;;; CNTX trace stack warn\n""\n;;; CNTX trace stack warn\n"
Command: (test '(err-vl 2 3))
Result: This is my error: too many argumentsnil
No errors!!!
; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on exception
But then after waiting a bit it then seems to work - sort-of (not even displaying that CNTX message):It seems the fail is simply calling the *error* defun with the message, but doesn't actually reset the lisp environment. I'll have to research a bit more, but I think I'm getting close now.Code:Command: (test '(err-vl "testing again"))
Result: testing again
No errors!!!
No errors!!!
Command: (test '(err-vl 1 2))
No errors!!!
Command: (test '(err-vl nil))
Result: This is my error: invalid argument type: stringp: nilnil
No errors!!!
No errors!!!
No errors!!!
I've just thought of another way of doing this. Similar to returning nil on errors, but allowing for nil as an accepted return value (as it should be, since it could mean a false or not-found or empty - which aren't necessarily "errors").
My idea was to use some "special" value which cannot be used anywhere else. I was thinking (a while ago) to make some temporary ename and pass that as an ObjectId so it could be checked in Lisp - similar to vl-catch-all-error-p does. However, the method started to become too cumbersome - not to mention it needed to be implemented in ARX (not DotNet).
So now, I've though: "Is there any possible value which can be returned from a LispFunction, which Lisp cannot possibly use in any "normal" situation?" And it seems there is: double.NaN (i.e. a double value which refers to an error condition "Not-a-Number"). Here's the test functionAnd when run in acad:Code:[LispFunction ("test-NAN")]
public static object testNAN(ResultBuffer arguments) {
return double.NaN;
Then to make an is-error function I used this:Code:Command: (test-NAN)
-1.#IND
And then ran it inside acad:Code:[LispFunction ("test-input")]
public static object testInput(ResultBuffer arguments) {
Document activeDocument =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor activeEditor = activeDocument.Editor;
try {
if (arguments == null) throw new ArgumentNullException();
if (args.Length < 1) throw new ArgumentException("No arguments passed in");
activeEditor.WriteMessage(string.Format("{0} arguments passed in\n", args.Length));
foreach (TypedValue element in args) {
activeEditor.WriteMessage(string.Format("\t{0}\t{1}\n",
LispDataType.GetName(typeof(LispDataType), element.TypeCode),
element.Value));
return true;
} catch (System.Exception e) {
activeEditor.WriteMessage(e.Message);
return null;
So it would be possible to test for such from Lisp.Code:Command: (test-input (test-NAN))
1 arguments passed in
Double NaN
T
But even easier - it would be possible to test for a NaN value direct inside Lisp. See these tests in acad:Notice the last item makes no logical sense? So the "is-error" function could simply be something like this:Code:Command: (= (test-NAN) 0)
nil
Command: (<= (test-NAN) 0)
T
Command: (>= (test-NAN) 0)
T
Command: (and (>= (test-NAN) 0) (<= (test-NAN) 0) (/= (test-NAN) 0))
T
Thereafter it would simply require that the DotNet needs to set the ErrNo and/or somewhere place the error message so it can be inspected from the Lisp side. And as optional extra the normal *error* can then be called as per my previous posts.Code:(defun is-error (value)
(and (>= value 0) (<= value 0) (/= value 0)))
I wanted to demonstrate a style of writing LISP that utilizes the 'and' expression.
It is why I like to have my expressions return a value or T for success and nil for failure.
To demonstrate.
Someone asked me yesterday how to explode all blocks in a block definition.
I has an old function using is if statements.
Now this is a rewrite of the code above using the 'and' syntax.Code:
;___________________________________________________________________________________________________________
; Function to explode all components in a block definition ;___________________________________________________________________________________________________________
(defun ExplodeItemsInBlock (objBlockDefinition / intCount objLast blnRerun)
(setq intCount (vla-get-count objBlockDefinition))
(while (not blnReRun)
(setq blnRerun T
intCount 0
(while (< intCount (vla-get-count objBlockDefinition))
(setq objLast (vla-item objBlockDefinition intCount))
(if (and (wcmatch (vla-get-objectname objLast) "AcDbBlockReference,AcDbMInsertBlock")
(errortrap '(vla-update objLast))
(progn
(if (errortrap '(vla-explode objLast))
(progn
(errortrap '(vla-delete objLast))
(setq blnRerun nil intCount (vla-get-count objBlockDefinition))
(setq intCount (1+ intCount))
; Standard error trap that returns nil for error or a value or T for success.
(defun ErrorTrap (symFunction / objError result XYZ123)
(if (vl-catch-all-error-p
(setq objError (vl-catch-all-apply
'(lambda (XYZ123)(set XYZ123 (eval symFunction)))
(list 'result))))
nil
(if result result 'T)
Which one do you prefer?Code:;___________________________________________________________________________________________________________
; Function to explode all components in a block definition rewritten to use 'and' syntax ;___________________________________________________________________________________________________________
(setq intCount 0)
(and (setq objLast (vla-item objBlockDefinition intCount))
(ExplodeItemsInBlock objBlockDefinition)
(princ)
P=
The last one definitely looks cleaner.
The trouble I have with only restricting yourself to nil/T as return value is that then you cannot make your DotNet LispFunction actually return useful data - you'll need to set some global variable if you want to return any data back to Lisp. For that reason I'd then want a error token instead of simply a "yes it succeeded" or "no something went wrong" value.
That way, you can still use it as per your example - your error trap would simply return nil if the function's return value is the token error. E.g.Code:(defun is-error (value)
(and (= (type value) 'REAL) (>= value 0) (<= value 0) (/= value 0)))
(defun errortrap (toEval / result)
(not (or (vl-catch-all-error-p (setq result (vl-catch-all-apply 'eval (list toEval))))
(is-error result))))
