Somebody can explian the logics behind revit input and survey input of bearing distance?
thanks
Printable View
thanks
Try it again and follow the bearings and dimensions around a the circle. Your first line and second line back on one another and the last two are going the same direction the way you typed them in the table. Perhaps you didn't notice the direction of the second N S E W after the angle.
I did try several times but no matter where I start or the direction of the circle I choose I can't do Revit to draw or tag the same direction as the survey. I make the property lines to close and draw correctly but the tags will read different from the survey.
I am really confuse. Thanks for your help anyway.
Hold on. don't give up I'll do it and post the table back in a minute
I started in the upper left and went around
Thanks Chirs for the time you are taking to help me!
I am Attaching a image with some comments and that is what I don't understand.
Be careful with surveys! In my experience they often have misleading or erroneous information. My pet peeve is the numbers. Usually they are rounded to 2 decimal places, which on some sites is not enough to reconstruct the geometry accurately. I have had licensed surveys that could not be made to close. On the Freedom Tower we went to 12 decimal places.
Also, do not decimalize the angles. Degrees, minutes and seconds are much more accurate. You are lucky to have a site with two orthogonal sides at 90 degrees. Most of the sites we deal with have no regular geometry at all.
Mother Nature abhors a straight line.
Check out this tutorial on Revit property lines I wrote a little while back...
http://forums.augi.com/showthread.php?t=10659
I've been away. Here's the skinny. It doesn't matter east or west after a 0 or 90 degree line. If you imagine you are walking the property line and you go marching along to the north 91 feet with a variance of zero degrees to the east. It is the same as a variance of zero degrees to the west.
I always think of the bearing as face the first direction and turn that many degrees to the second direction i.e N 45 E clockwise N 45 W counterclockwise.
Thanks guys for all your help.
Scott great post. I just wonder if Revit should not be aware of this difference between the way surveyors describe property and the way Revit input data? The work around is great but should be easier don't you think so?
