Custom Sheet Data Edit Muliple
Hi,
I am looking for a way to edit field entries for multiple sheets at a time. I have several disciplines that need to select all their sheets (under their subset) and replace a value in a field. Is there a way to do that without right clicking and editing the properties of each sheet individually?
David
Re: Custom Sheet Data Edit Muliple
Hi,
Take a look at SSMPropEditor.
http://www.jtbworld.com/SSMPropEditor.htm
ddraynor
I've purchased The SSMPropEditor and It's the best investment I have made in my life.I'm editing custom sheet set data regarding drawn-by and checked by and lot of other data for hundreds of sheets in seconds while it took me days to do it
Not sure if this is exactly what you are saying but I made a request for custom properties per subset...
http://forums.augi.com/showthread.ph...337#post953337
Using these steps you can use multiple edits.
Ctrl + Click each sheet tab at the bottom of your worksheet (selected sheets will turn white).
While selected, any formatting changes you make will happen in all of the selected sheets.
Double-click each tab when you are done to un-select them.
saisatcharitrapdf802200
I'm not certain editing layout properties is related to the SSM data editing this thread is discussing.
You can always start a new thread with your question or just post your comments regarding this thread here.
