Reading Databases with ADOX library
I have used the DAO type library for years and ADO now for a year or so for reading databases into LISP.
This code accepts a database file name and an sql string to create a record set that is converted into a list of sublists (first sublist is the fields)
Imports System
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports ACADApplication = Autodesk.AutoCAD.ApplicationServices.Core.Application
Imports ADOX
Public Class Class1
' Global Flags set to 3 is a flag that prints messages to both command line,
' console and set to 7 to display message box if desired.
Shared globalFlags As Int16 = 1 + 2
#Region "Public Access Data Object (ADOX) functions"
''' <summary>
''' </summary>
''' <param name="rbfArguments"></param>
''' <returns></returns>
''' <remarks>LISP Syntax: (ADOXToList "c:\\acad\\newmdb.mdb" "Select FirstName, LastName, Address From AddressTable where LastName Like '%'"")
''' </remarks>
<LispFunction("ADOXtoList")> _
Public Function ADOXToList(ByVal rbfArguments As ResultBuffer)
Try
Dim arrArguments As TypedValue() = rbfArguments.AsArray
If arrArguments.Length > 1 Then
Dim strFullName As String = FileFind(arrArguments(0).Value.ToString)
If strFullName Is Nothing Then
MessageWrite("File ''" & arrArguments(0).Value.ToString & "'' Not Found", globalFlags)
Return Nothing
End If
Return DatabaseRead(strFullName, arrArguments(1).Value.ToString)
End If
MessageWrite("error: Too Few Arguments", globalFlags)
Catch exception As System.Exception
ErrorMessage(Err, globalFlags)
End Try
Return Nothing
End Function
''' <summary>
''' Function to read a database given a filename and a strucutred queiry language statement
''' and return the recordset as a list of sublists
''' </summary>
''' <param name="strFullName"></param>
''' <param name="strSQL"></param>
Public Function DatabaseRead(ByVal strFullName As String, ByVal strSQL As String)
Dim connection As New ADODB.Connection
Dim catalog As New ADOX.Catalog
Dim recordSet As New ADODB.Recordset
Try
Dim rbfReturn As New ResultBuffer
Dim strConnection As String = ConnectionString(strFullName)
If strConnection IsNot Nothing Then
connection.Open(strConnection)
catalog.ActiveConnection = connection
recordSet = connection.Execute(strSQL)
If recordSet IsNot Nothing Then
rbfReturn = RecordSetToResultBuffer(recordSet)
End If
'Clean up
connection.Close()
catalog = Nothing
connection = Nothing
Return rbfReturn
End If
Return Nothing
catalog = Nothing
If connection IsNot Nothing Then
If connection.State = 1 Then connection.Close()
End If
Return Nothing
End Try
End Function
''' <summary>
''' Function to convert a record set to a list of sublists
''' </summary>
''' <param name="recordset"></param>
''' <returns>ResultBuffer (list of sublists)</returns>
Public Function RecordSetToResultBuffer(ByVal recordset As ADODB.Recordset)
Try
If recordset IsNot Nothing And Not recordset.BOF Then
recordset.MoveFirst()
rbfReturn.Add(New TypedValue(5016, -1))
For Each field As ADODB.Field In recordset.Fields
rbfReturn.Add(New TypedValue(5005, field.Name))
Next
rbfReturn.Add(New TypedValue(5017, -1))
Do While Not recordset.EOF
rbfReturn.Add(ObjectToTypedValue(field.Value))
Next
recordset.MoveNext()
Loop
Return rbfReturn
End If
End Try
Return Nothing
End Function
''' <summary>
''' Function to get the correct connection string for each type of database file
''' and 64 bit and 32 bit architectures.
''' </summary>
''' <param name="blnSecurity"></param>
''' <returns>Connection String as string or nothing </returns>
Private Function ConnectionString(ByVal strFullName As String, _
Optional ByVal blnSecurity As Boolean = False)
Try
Dim strProvider As String = Nothing
Select Case System.IO.Path.GetExtension(strFullName).ToUpper
Case ".ACCDB"
strProvider = "Microsoft.ACE.OLEDB.12.0; Data Source="
Case ".MDB"
If IntPtr.Size = 8 Then '<- 8 is 64x architecture
Else
strProvider = "Microsoft.Jet.OLEDB.4.0; Data Source="
End If
Case ".MDF" Or ".UDF"
End Select
If strProvider IsNot Nothing Then
Return "Provider=" & strProvider & "'" & strFullName & "'" & ";Persist Security Info=" & blnSecurity.ToString & ";"
End If
End Try
Return Nothing
End Function
#End Region
' Region of Message Functions
#Region "Public Error Message functions"
''' <summary>
''' Sub routine for printing error messages to the command line and console
''' </summary>
''' <param name="objError"></param>
''' <param name="flags"></param>
Public Shared Sub ErrorMessage(ByVal objError As ErrObject, Optional ByVal flags As Int16 = 3)
If objError.Number <> 0 Then
Dim strMessage As String = objError.Source & "-->" & objError.Description
MessageWrite(strMessage, flags)
End If
End Sub
''' <summary>
''' Function for finding a file in the AutoCAD search path or specified folder.
''' </summary>
''' <returns>File Full Name with Path </returns>
Public Shared Function FileFind(ByVal strFullName As String)
Try
Dim database = HostApplicationServices.WorkingDatabase
strFullName = HostApplicationServices.Current.FindFile(strFullName, database, FindFileHint.Default)
If strFullName IsNot Nothing Then
Return strFullName
End If
End Try
Return Nothing
End Function
''' <summary>
''' Sub routine for writing to command line, console and/or message box.
''' </summary>
''' <param name="strMessage"></param>
''' <remarks>
''' 0 Dont write messages to command line or console
''' 1 Write Message to Console
''' 2 Write Message to Command Line
''' 4 Write in a message box
''' </remarks>
Public Shared Sub MessageWrite(ByVal strMessage As String, Optional ByVal flags As Int16 = 3)
If (flags And 1) = 1 Then _
Console.WriteLine(strMessage.ToString)
If (flags And 2) = 2 Then _
ACADApplication.DocumentManager.MdiActiveDocument.Editor.WriteMessage(strMessage.ToString)
If (flags And 4) = 4 Then _
MsgBox(strMessage.ToString)
End Sub
#End Region
End Class
Re: Reading Databases into LISP
This region needs to be added to the above class (I ran out of room)
#Region "Public ObjectToTypedValueer functions"
' Blank (like returned by princ)
Public Shared Function ObjectToTypedValue() As TypedValue
Return New TypedValue(LispDataType.None, -1)
End Function
' Integers (32 bit or other)
Public Shared Function ObjectToTypedValue(value As Integer) As TypedValue
Return New TypedValue(LispDataType.Int16, value)
End Function
' 16 bit integers
Public Shared Function ObjectToTypedValue(value As Int16) As TypedValue
End Function
' Doubles
Public Shared Function ObjectToTypedValue(value As Double) As TypedValue
Return New TypedValue(LispDataType.Double, value)
End Function
' Strings
Public Shared Function ObjectToTypedValue(value As String) As TypedValue
Return New TypedValue(LispDataType.Text, value)
End Function
' Booleans
Public Shared Function ObjectToTypedValue(value As Boolean) As TypedValue
If CBool(value) Then
Return New TypedValue(LispDataType.T_atom, -1)
End If
Return New TypedValue(LispDataType.Nil, -1)
End Function
' 2d Points
Public Shared Function ObjectToTypedValue(value As Point2d) As TypedValue
Return New TypedValue(LispDataType.Point2d, value)
End Function
' 3d Points
Public Shared Function ObjectToTypedValue(value As Point3d) As TypedValue
Return New TypedValue(LispDataType.Point3d, value)
End Function
#End Region
1 Attachment(s)
The reference files are:
Attachment 95077
Re: Reading Databases with ADOX library
You might also want to check what nullptr did here: http://www.theswamp.org/index.php?topic=28286.0
I.e. an embeddable / stand-alone database file (Sqlite).
2 Attachment(s)
This is a sample of calling this function from lisp
(defun C:ADOX ()
(textscr)
(ADOXToList "c:\\acad\\newmdb.adodb"
"Select FirstName, LastName, ZIPCode From AddressTable where State Like 'OR'")
This is the function run.
Command: ADOX
(("FirstName" "LastName" "ZIPCode") ("John" "Doe" 97222) ("Jane" "Doe" 97222) ("Bill" "Note" 97208))
