Rendering Issues
Hey,
This is my first post here so bear with me.
I have 5 models that need to be merged and rendered. However, when all the models are merged together, it doesn't render properly. It looks like bits and pieces of the model disappear.
When i render each individual model, it renders fine but as soon as I merge 2 or more models together, I constantly get this problem.
Any help would be appreciated.
1 Attachment(s)
Re: Rendering Issues
here's an image of the problem
In Presenter, go to the rendering tab and under templates, select photorealistc>high quality and drag in to the workspace. Double click on the high quality icon and uncheck all of the anti-aliasing boxes (4 total). If you re-render, the problem should be corrected.
Cheers,
Scott
Thanks! It worked.
Any idea why it was doing that? It's never happened to me before. Even with bigger models.
I having the same issue above. I tried the remove all of the anti-aliasing options, but that didn't work for me. However there is a file that I appended to the main file that is my main issue. If I turn it off and/or remove it, I am able to zoom in really close without any parts of the models disappearing or clipping effect. Overall I should be able to append whatever files is needed and not have this issue.
Any other suggestions? Thanks!!!!
