1 Attachment(s)
Re: pipe weight in the spec
Hi Scott, there are a few solutions you could explore:
1.Visit the Autodesk App store, I think there is a Metric ASME catalog available for purchase, although:
2.It sounds like all you want are metric lengths and weights but imperial pipe diameter callouts correct?
In that case I would simply build your specs using the included ASME catalog even though it's all imperial
and when it comes to setting up a project just select "Metric" unit settings and then select "Inches (Mixed Metric)" for the reporting of nominal diameters.
Plant 3D will handle the conversion of units for you. See the pic below.
As far as manual go, check these out:
Tailoring AutoCAD P&ID and AutoCAD Plant 3D
Plant 3D Isometrics
Report Designer Manual
There are also a bunch of videos on youtube from Autodesk and others, just do a search and you'll find a ton of stuff.
Attachment 104887
