1 Attachment(s)
Navisworks, 3D Rebis, AutoCAD 2009
Hello All, (new here)
programs: Naviswork Freedom 2010, Bentley 3D Rebis Pipe Modeling. Exported pipe model in dwf format. Opened in Navis, but my pipe or equipment does not show up correctly. ONLY the fittings show up correctly. I don't know what is causing this.
Used AutoCAD 2006 and an earlier version of Navisworks, everything worked great. Since upgrading nothing is working together.
Any help would gratefully be appreciated.
daniel
Re: Navisworks, 3D Rebis, AutoCAD 2009
Hi Daniel,
Have you tried to open the DWF in Autodesk Design Review to verify that the issue is not Navisworks related? My guess is that Bentley is not exporting the pipe entities properly. DWF is just a container, so if it's not exported properly, it won't show up in Navisworks. The wireframe views are suspect of not having the proper Object Enabler (OE) installed.
Cheers
