Re: Dynamic block names..
There is a way through pure lisp without using vla/vlax. The trick is to find those pesky dictionary objects which link the block to its original. E.g. say you have a block Insert's DXF data list:
- Directly after the 102 code (102 . "{ACAD_XDICTIONARY") there should be a code 360 which points to the dictionary object's ename.
- This in turn has another 360 directly following (3 . "AcDbBlockRepresentation")
- This points to another dictionary with a 360 just after (3 . "AcDbRepData")
- This one's a ACDB_BLOCKREPRESENTATION_DATA dictionary. Its got a 340 code at its end.
- Which points to the original block record of which you can get the name from its code 2
Here's some sample defun which takes an INSERT's ename / entget list:
;; Get Block's effective name without ActiveX
(defun EffectiveName (en / ed d1 d2 d3 br)
(if (= (type en) 'ENAME) ;Check if ename is passed as argument
(setq ed (entget en)) ;Get the dxf data
(setq ed en) ;Else assume dxf data as argument
) ;_ end of if
;; Get the ACAD linking dictionary
(setq d1 (entget (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") ed)))))
;; Get the ACAD black representation dictionary
(setq d2 (entget (cdr (assoc 360 (member '(3 . "AcDbBlockRepresentation") d1)))))
;; Get the Representation Data Dictionary
(setq d3 (entget (cdr (assoc 360 (member '(3 . "AcDbRepData") d2)))))
;; Get the block record
(setq br (entget (cdr (assoc 340 d3))))
;; Return the block's name
(cdr (assoc 2 br))
) ;_ end of defun
Worked like a charm as usual! Will have to just run with it for now, figure out what's actually happening over the weekend maybe, if possible.
Can't thank you enough, you just saved me so much headache. :)
