How do I change my settings so that my dimensions will print in color? I have other color items that will print in color, but my dimensions won't. I've seen this done but can't figure out how.
Thanks.
Printable View
Thanks.
I have questions... what are you doing for plotting? CTB with color maybe?
How do you have your dimensions set up? ByLayer or assigned colors to the dimension entities in the dimstyle?
If ByLayer, what color is the layer your dimensions are on?
Quick answer: Either make sure your dimensions' colors are ByLayer and put them on a layer with a color you want to print with your plot style.
Or if your dimension colors are set in the dimstyle, change those colors to plot the color you want with your plot style.
HTH
Sorry I should have clarified. This is just to print to PDF. Not printing directly to the printer.
