I have attached file.
hope somebody helps..
give advice
comment
Printable View
give advice
comment
You need to give us more information. What is wrong with the code? What do you want to do? Attach a sample dwg file to test the dvb on.
The code is too lengthy I don't know some how please make it shorter.
Thanks.
You're right, it is too long. You need to refactor it. You have 6 bays. Create a subroutine that creates 1 bay and make it with an argument that takes an double for the length. Then you can just call the subroutine for each length, e.g.:
Also, consider using With statement, e.g.Code:CreateBay(4150)
An alternative is to create a dynamic block for 1 bay that can be stretched to the desired length.Code:With adim
.TextHeight = 1
.Color = acByLayer
.Layer = "0"
.Update
End With
I have the same problem.
