Thank you for your helpful post. The resulting layout tab names are in alphabetical order, is there a way to get results listed in same order as shown in drawing?
Printable View
https://forums.autodesk.com/t5/visua...524295#M315919
<snip>
... consider this pseudo-named, custom LayoutListSelected function:
https://forums.autodesk.com/t5/image...v=mpbl-1&px=-1
<snip>
Hi Dear,
this works fine and great. thanks for this code.
can u please update this code as few implements required for me. if possible
1. Implement the command name, since i can use when it required by loading the lisp in startup suite
2. can it be export in .csv format with the file name and layout name.
3. the exported .csv file need to autosave in the same location where the cad files is there.(it should not open and show the result)
it would be more helpful for me if these are implemented in this code.
