Non-uniform SCALE command for objects
I run into situations where groups of non-block drawing objects are just fine dimensionwise in one axis direction, but I would like to alter the size along just one axis while preserving the other(s).
Is there an existing command that will do this so I don't have to recreate the objects from scratch?
Jeff
Re: Non-uniform SCALE command for objects
jtdonville
Jeff
A workaround would be to convert the objects into a block, scale using the properties palette and then explode the block.
