1 Attachment(s)
GD35-5: Advanced DWF™ Publishing from AutoCAD®: Tips and Tricks
Instructors: Brian Mathews - Autodesk, Inc.
Class Description: In this session, you will learn the advanced tricks for publishing DWF data from AutoCAD including:- When to use the Sheet Set Manager vs. the Publish command
- How to publish 3D data to DWF
- How to publish AutoCAD Block attribute data to DWF as object properties
- How to securely filter what data is published to DWF
- Defining page templates for DWF
- Using page setup overrides for DWF
- How to enable merge control support with DWF
- Publishing DWF automatically to Autodesk Buzzsaw
- How to leverage other Sheet Set Manager features such as properties and sheet indices.
