Is there a way to remove smaller rectangle at the top of this structure in the profile view?
Its a "Slab Top Rectangular Structure" under the Cylindrical Structure Civil 3D catalog.
Printable View
It would require a trip into to part builder and reducine and or removing that component from the part.
Or using a user defined block insted of the catalog part
Is there a source for an expanded catalog of parts?
Well, Florida DOT has a civil3d package, while a lot of it is useless for anything other than FDOT projects - there is a very large catalog of custom drainage structures and pipes.
Other State DOTs may have their own flavors
The small rectangle it the structure frame.
Option 1: Swap this structure for the Rectangular Junction Structure as it has no frame.
Option 2: Open this part in partbuilder and edit the available values for the frame height to include a selection of 0.0001. (So small it won't be noticeable)
https://www.fdot.gov/cadd/downloads/...22caddsoftware
The install will grad ALL of the FDOT stuff, you'll need to point your pipe catalog to their and build a new parts list
