I am tring to Publish from AA 2008 and I only get the First 2 Sheets and then nothing.
Is anyone else have issues with 08 Publish.????
Printable View
Sill having the same Issue. Anyone else having Problems with Publish.???
Nope. Mine publishes fine. Are you using PN? Check publishcollate and set it to 1 (if it isn't already).
Publish is good for me too....
Check your log for errors. Maybe some clue might show up there...
I find that its usually a loose nut on the end of the keyboard... (ie.. me)
Also make sure you have valid page setups applied to or imported in the publish box for each sheet.
A little more info as to what is going on would be most appreciated to help get the best answer.
