Match properties
I have a problem with match properties. When I select a object that I want the properties changed, all the entities that touch that object change also. I'm sure this is just a setting but I can't think of where it would be. If you have an answer I would appreciate it.
RE: Match properties
Could they be part of a group?
Hi
Please note I've *moved* this thread from the AutoCAD Customization Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
I have the same problem, i havnt looked into it too much but it results from the new hatch associativity. A quick fix is to uncheck the hatch composition associative box, for the moment i have found nonassociative hatches the lesser of two evils.
I have unchecked the nonassosiative hatch and like you said it is a quick fix. In order to stretch an entity and have the hatch stretch with it. I am currently working in release 2004 and I know that earlier releases allowed this to work.
Hi
Take a look at the system variable PickStyle (try setting to 0 or 1 instead of 2 or 3).
Have a good one, Mike
Thanks that did it for me.
