2 Attachment(s)
how a door reads in plan ( i changed a double door which each leaf swings to a double fixed)
i opened an existing door that i'm using, saved as "fixed" and rotated the symbolic lines 90 to be closed and deleted the swing . In plan the symbolic lines represent the 2" thick door.However, when i load into project the fixed door in plan appears to have 5" thick doors.
and another thing.....as mentioned i selected the existing door family to edit (make fixed), it is to the left in the elevation and i noticed in the elevation that the door is shorter and i cant seem to make it taller ( why is that?)....changed height in properties and even went back to the "fixed door" family and changed there as well
Re: how a door reads in plan ( i changed a double door which each leaf swings to a double fixed)
Regarding plan view, perhaps your symbolic line of the door has attached itself to a reference plane inside your family... (perhaps the centerline of wall)
Try to break this relationship. Also try to place a dimension constraint on the two lines that make up the leaf thickness.
Regarding elevation view, i would have to see the family to understand more.
