Re: Translate CUIx into CUI
cadconcepts
Hi All-
Typically, when I get a new version of AutoCAD I would go into my CUI file with a text editor and globally change the menugroup name to match the AutoCAD version number. However, in AutoCAD 2010, the cui is now a cuix which appears to be a compiled menu file. Does anyone know if there is a way to save the cuix into a file that can be edited with an external editor? Thanks.
Manuel A. Ayala
The CUIX format is simply a compressed file. Rename the file's extension to ZIP and you can access its contents.
But why in the world are you doing this anyway?
Robert-
Thanks for the info. That's clever.
Manuel
RobertB
Also, if you use something like 7-ZIP, it will recognize that it's a ZIP file without having to rename it.
after you open them with 7-zip how do you work with them?
scotts.217338
Editing the CUI file directly is not supported. You do so at your own risk. The CUI file is an XML-formatted file, so any text/xml editor can be used to edit the file.
