RE: Command Shortcut keys have ceased to work
Hi Matt
Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
Below snippet is taken from the small print found on the Forum General page ( Click HERE to see a screen capture )...
<snip>
New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
</snip>
Thanks, Mike
Forum Moderator
Hi
First I would recommend checking, is your Acad.pgp file being loaded.
At the AutoCAD Command Line type the following...
Command: (findfile "Acad.pgp")
What is returned ?
Have a good one, Mike
Mike,
"C:\\Documents and Settings\\mgb3\\Application Data\\Autodesk\\AutoCAD
2004\\R16.0\\enu\\support\\Acad.pgp"
Matt
Originally Posted by mgb3
"C:\\Documents and Settings\\mgb3\\Application Data\\Autodesk\\AutoCAD 2004\\R16.0\\enu\\support\\Acad.pgp"
Hi
Open this file in a "Plain" ASCII Text Editor.
Are the Copy, Move, Rotate, etc commands correctly defined there with their corresponding quick-keys ?
Yes, they are all there.
Hi
What happens if you use the _.ReInit command ?
I've had this happen before with one of my laptops. I fixed it with bringing back one of my back up ACAD.pgp files. As much as I could figure something got corrupted but I could never fix it looking line by line.
Also should not mgb3's path read "C:\Documents and Settings\mgb3\Application Data\Autodesk\AutoCAD 2004\R16.0\enu\support\Acad.pgp". Notice on the earlier post the \\ we're used.
Hi
Nope! seeing the LISP function "findfile" was being used to return the path.
Well I tried a reboot yesterday to no avail but after starting up this morning all my commands are back and working again, and I no longer need to fiddle.
Perhaps somethings to do with the network and network profile?
Thanks for your help folks.
Matt
