Very nice! That looks like a well constructed keyboard.Quote:
Originally Posted by jhohman
I think the one I'm SLOOWLY working on right now will be less expensive in the long run, but props for finding a cool product.
Printable View
Couldn't you just do that by customizing your tool bar? I've customized mine so that I've got commands such as Cancel, Snapbase, Regen, Copy with base point, Paste as block, various scale buttons. We've even created a command that flattens a 3d drawing.Quote:
Originally Posted by todw
Simple as this may sound but it definately helps when you're feeling tired and can't be bothered to move your hand just to press ESC.
bob-kalsi, you get tired of pushing keys? :-)
Definately and interesting product........I wouldn't think it would be useful for AutoCad.
Once the shortcuts are memorized the user hardly ever looks at the keyboard.
Nope, AutoCAD is not the only program running on my computer.
And a misplaced "press the button" is one to mush.
A physically different keyboard, no thank you.
A software modified keyboard yes.
Shift R rotate, Shift C copy, Shift M mirror . . . .
: ) Happy Computing !
kennet
Hi,
This is a very interesting conversation. Since r14 we have been using a product called autohook.
(http://www.command-digital.com/) This is a very small program that allows you to re-program all keys on your keyboard. Yes, F keys, arrow keys, 'insert", page up" etc. You can also multiply this by adding shift, control or alt. I think all of us probably use the pgp file or some lsp files for l = line m = mirror. I have my arrow keys set for 0, 90, 180, 270 and ctl arrow for 45, 135 etc. Very handy.
This is a great product, check it out.
http://www.ergodex.com/mainpage.htm
anybody using something like this?
About 15 years ago when we upgraded to 486 machines, I got a Gateway 2000 with a 120 key programmable keyboard. 2 or 3 machines later, I am still using it. I have replaced the "F" & "J" keys about 3 times and some keys are making strange noises when pressed but I just can't give it up.
Was that Optimus $1500 dollars? How do you justify that cost to management?
I'm on board if the product does what it should, and costs what it should. I used the Nostromo Speed Pad n52 in AutoCAD 08. Others on here can attest to how well it works, when it works well. Cost is low too, about $30.
I really like the idea of having caps you can insert icons under. I had a "map" on the monitor for my Speed Pad. Perhaps if the company you contacted can make a product similar, and package it with a utility specific for AutoCAD, it may catch on.
Anyhow, I'm in, and I'd be happy to alpha or beta test anything you work out. :beer:
I have X-keys. Fully programmable with 1 key being a toggle between 2 levels. My 20 key pad accommodates 38 commands / macros. Easy to program & it has clear button caps so you an make your own labels. Even gives specs so you can draw a grid in ACAD & type the labels to print & cut. I've been using mine for over 7 years. I programmed it for Raster Design commands, but threw in a few for repetitive ACAD commands.
