3 Attachment(s)
CM433-3L: AutoLISP® Cheat Sheet for CAD Managers - Repeat
Session: CM433-3L
Title: AutoLISP® Cheat Sheet for CAD Managers - Repeat
Instructor: Robert Green
Course Description: Learn how to create your own keystroke-saving functions, delete commands, redefine commands, load CUI files, set workspaces, control system variables, call external programs, and more using AutoLISP. Then compile and deploy it all via your network to achieve single point of control over your AutoCAD®-based programs with far less hassle and complexity than you think. This course will leverage your CAD management and AutoCAD experience to throw you into the AutoLISP pool so you can learn the syntax as you go along. At the end of the class, you will have a framework you can begin using as soon as you get back from AU. If you don't know AutoLISP, you will learn as you go, and if you do know AutoLISP, you're sure to pick up some cool CAD management ideas. If you've wanted to know more about how AutoLISP can help you manage your AutoCAD-based tools, you don't want to miss this class.
