1 Attachment(s)
Grid Dimension not Changing After Scale Block
Hi,
I attach Cad file, one is block grids another is explode grid. i copy/past in working file & changed scale but only grid dimension(Block) did not change. Dimension Style are same so i did not change DIMLFAC (Dim Scale Linear)
Actually i need dim 4500mm after explode. But grid Dim in block is 9000mm, if check measurement its 4500mm??
Thanks & Regards,
JAYHAR.M.J
Detailing Engineer
________________________________________
CICON Rebar Solutions Pvt. Ltd.
DD Trade Tower, Kaloor-Kadavanthara Road,
Kaloor, Ernakulam, Kerala,India - 682017
E-mail : jayharcicon@gmail.com Mob : +91-9961032444
Re: Grid Dimension not Changing After Scale Block
The scale of the block in your drawing is .5. Change the scale to 1 and explode it.
Unless I am missing something, I think that's the issue.
cwbrodie
i would like to work without explode. block of scale that i changed but dimension didn't change.
