Summary: set the first elevation tag and all following will adjust with distance from the first
Description: right now i have to manually input the geodetic elevations which are required by our cities here on our elevation drawings. errors can work their way in by this method. it would be easier if you could set the grade elevation and all other elevation that follow after would be in relation to the first one. so if you have to change one the others in the set would follow as well.
Product and Feature: AutoCAD Architecture - Elevation Labels
Submitted By: rickw.250500 on 10/25/2016
