Hello everyone
Please I need a help with this lisp routine
1-I like to put a default value for "Grid Spacing" user input
2-I like to put thousands commas in grid labeling
Thanks a lot:)
Code:(defun c:hgg ()
(command "undo" "m")
(setq *osnap (getvar "osmode"))
;(command "osnap" "endp")
(setq p1 (getpoint "\nLower Left Corner: ")
p2 (getcorner p1 "\nUpper Right Corner: ")
p100(list (car p1) (cadr p2))
p200 (list (car p2) (cadr p1))
(command "osnap" "none")
(command "-layer" "m" "Grid" "color" "255" "" "")
(command "-layer" "m" "Label" "color" "7" "" "")
(command "-style" "tahoma" "tahoma" ss "1" "0" "n" "n" "n")
(command "layer" "s" "Grid" "" "linetype" "s" "bylayer" "" "color" "5")
(command "_.PLINE" p1 p100
p2 p200 p1 "")
(setq d (getdist "\nENTER GRID SPACING:"))
(setq ss (getdist "\nENTER HEIGHT OF TEXT:"))
(setq v (/ 0 d));To set the label at the same horizontal level of the line
(setq qq (/ ss 4))
(setq x1 (car p1))
(setq y1 (cadr p1))
(setq x2 (car p2))
(setq y2 (cadr p2))
(setq x100 (car p100))
(setq y100 (cadr p100))
(setq x200 (car p200))
(setq y200 (cadr p200))
(setq f1 (/ x100 d))
(setq f2 (fix f1))
(setq f2 (float f2))
(if (< x100 0) (setq f3 f2))
(if (>= x100 0) (setq f3 (+ f2 1)))
(setq f4 (* d f3))
(setq x3 f4)
(setq n1 (/ y1 d))
(setq n2 (fix n1))
(setq n2 (float n2))
(if (< y1 0) (setq n3 n2))
(if (>= y1 0) (setq n3 (+ n2 1)))
(setq n4 (* d n3))
(setq y3 n4)
(setq y y1)
(if (> y100 y1) (setq y y100))
(if (> y200 y100) (setq y y200))
(if (> y2 y200) (setq y y2))
(ngridy)
(defun ngridy ()
(setq h1 (list x1 y3))
(setq h11 (list x2 y3))
(setq t1 (list (- (+ x100 v) qq) (+ y3 v)))
(setq t2 (list (+ x200 v) (+ y3 v)))
(setq xrr (+ x2 (* 2 qq)))
(setq prr (list xrr y2))
(setq s1 (rtos y3 2 0))
(command "layer" "s" "Grid" "" "linetype" "s" "bylayer" "" "color" "bylayer" "line" h1 h11 "")
(command "layer" "s" "Label" "" "color" "bylayer" "text" "s" "tahoma" "j" "mr" t1 0 s1)
(command "mirror" "l" "" p100 p1 "" "move" "l" "" p100 p2 "justifytext" "l" "" "ml")
(setq y3 (+ y3 d))
(if (< y3 y) (ngridy))
(setq x x1)
(if (> x100 x1) (setq x x100))
(if (> x200 x100) (setq x x200))
(if (> x2 x200) (setq x x2))
(ngridx)
(defun ngridx ()
(setq v1 (list x3 y1))
(setq v11 (list x3 y2))
(setq r1 (list (- x3 v) (+(+ y2 v) qq)))
(setq r2 (list (- x3 v) (+ (+ 1 y2) v)))
(setq ydd (- y1 (+ (* qq 2) ss)))
(setq pdd (list x1 ydd))
(setq w1 (rtos x3 2 0))
(command "layer" "s" "Grid" "" "linetype" "s" "bylayer" "" "color" "bylayer" "line" v1 v11 "")
(command "layer" "s" "Label" "" "color" "bylayer" "text" "s" "tahoma" "j" "bc" r1 0 w1 )
(command "mirror" "l" "" p100 p2 "" "move" "l" "" p100 p1 "justifytext" "l" "" "tc")
;(command "copy" "l" "" p100 pdd "justifytext" "l" "" "tc")
(setq x3 (+ x3 d))
(if (< x3 x) (ngridx))
(Setvar "osmode" *osnap)(command "offset")
(H-GRID)
(princ "To undo all,type the command Undo and select B")
(princ)
(princ "\nTHIS LSP IS ONLY TO DRAW GRID FOR ORTHO FRAME, Type (hgg) to start")
