Ceiling Grids and Hatch Editing
Summary: When editing hatch or a ceiling grid holding down the Ctrl key would continue the add or remove vertex command.
Description: It is very time consuming to hover over the vertex and have to pick add or remove each time when editing hatches and ceiling grids. It would be much faster to hold down the Ctrl key after picking add or remove from the initial command, then you could just continue adding or deleting vertexes.
Product and Feature: AutoCAD Architecture - Ceiling Grids
Submitted By: Dan Iacovoni on 11/13/2014
The wish has been edited. Below are the updated details.
Text with arrow left justification
Summary: The left justification for text with an arrow should be anchored at the left justification position.
Description: The left justification for text with an arrow should be anchored at the left justification position. Once text and a callout arrow are placed with left justification the left justification point should anchor the text. Then when editing the text the modified text would change left justification positions and jump to the right. This is very annoying to have to realign the text after editing.
Product and Feature: AutoCAD Architecture - Callouts
Description: The left justification for text with an arrow should be anchored at the left justification position. When editing the text the modified text would not move positions and jump to the right. It is very annoying to have to realign the text after editing.
