Command to Isolate Object(s)
Summary: The ability to isolate an object or set of objects, regardless of layers.
Description: Could we please have a set of buttons which allow the user to isolate an object(s), without seeing or interfering with any other objects. then once you have finished modifying the object, use a button to bring all the objects back.
These commands Are available in CADDuct Solids.
How Used: This would enable users to isolate and work on solid objects, when the object is in the middle of a complex model.
Feature Affinity: Drawing Tools 2D
Submitted By: Mike Robinson on March 19, 2008
Re: Command to Isolate Object(s)
Did you try right click - Isolate objects? This works for me in ACA, I don't have plain AutoCAD, but I'm sure it must have it as well.
sgoodmansen
It is not a feature of vanilla AutoCAD, only verticals.
