I was wondering if anyone had a routine to do a find replace on text (single line/mtext) nested inside of multiple different blocks in one drawing.
Thanks
Printable View
Thanks
It's possible to create one, but is a bit of an overkill if it's just for a handfull of blocks types. In which case it's easier just to edit the block.
Just had a check, it seems to work fine:
This only uses the command line.Code:(defun c:TxtSR (/ ss en ed blk n str1 str2)
(prompt "Select entities to search through: ")
(setq ss (ssget)
n 0
) ;_ end of setq
(setq str1 (getstring t "Enter string to search for: "))
(setq str2 (getstring t "Enter string to replace with: "))
(defun ReplaceString (ed / str m)
(setq str (cdr (assoc 1 ed))
m 0
) ;_ end of setq
(while (setq m (vl-string-search str1 str m))
(setq str (vl-string-subst str2 str1 str m))
(setq m (1+ m))
) ;_ end of while
(setq ed (subst (vl-list* 1 str) (assoc 1 ed) ed))
(entmod ed)
(entupd (cdr (assoc -1 ed)))
ed
) ;_ end of defun
(while (< n (sslength ss))
(setq en (ssname ss n)
ed (entget en)
) ;_ end of setq
(if (assoc 1 ed)
(setq ed (ReplaceString ed))
) ;_ end of if
(if (= "INSERT" (cdr (assoc 0 ed)))
(progn
;; Search through block's entities
(setq blk en
en (tblsearch "BLOCK" (cdr (assoc 2 ed)))
) ;_ end of setq
(if en
(setq en (cdr (assoc -2 en)))
) ;_ end of if
(while (and en (setq ed (entget en)))
(if (assoc 1 ed)
) ;_ end of if
(setq en (entnext en))
) ;_ end of while
;; Search through attributes following block
(setq en (entnext blk))
(if (= "ATTRIB" (cdr (assoc 0 ed)))
) ;_ end of if
) ;_ end of while
(entupd blk)
) ;_ end of progn
) ;_ end of if
(setq n (1+ n))
) ;_ end of while
(setq ss nil)
(gc)
) ;_ end of defun
Moderator Note:
Removed Comments Per Forum Guidelines.
Thank you
That works exactly the way I would like it too.
Reason why I need it is for job specific changes to blocks that only happen one every ten jobs. And to explode/burst some of these blocks creates other problems.
Thanks again.
